Might be tough to enclose that big sob. you have enough room around it to do so?
Nope, it was a direct fit in the existing cartridge, which is a replica of the Super HX40. It sure is purdy......too bad it's hidden once installed.Any machining required or? That billet wheel is a work of art.
Nice, can't wait for your results.Nope, it was a direct fit in the existing cartridge, which is a replica of the Super HX40. It sure is purdy......too bad it's hidden once installed.
I'd love to find out how that combo acts. I hope you try it and report back!This kind of thing is precisely why I kept discussing Holset's years back when the 6.5 community was just starting to look at turbo options. Experimenting with Holsets or Holset CKO's is relatively easy, cost-effective, and considerable options.
Looking forward to seeing how you like this combination. My truck has the NV4500, 3.73's, 33" tires. It occasionally tows a heavy 26' GN carhauler, so I went with the CKO HX40Wii, for spool up/recovery on shifts.
Will be curious to see how your new combination spools up. With the 3" body lift done, I'm pretty sure there's adequate clearance for a center mount turbo. A true 4" downpipe & more symmetrical & efficient header/up pipe combo might spool the bigger turbine section fast enough to keep from falling below the torque curve on shifts?
6.5, 8in8or and you have perhaps done the most mods I've seen then again I haven't seen them all but I'm very impressed with each projects.This kind of thing is precisely why I kept discussing Holset's years back when the 6.5 community was just starting to look at turbo options. Experimenting with Holsets or Holset CKO's is relatively easy, cost-effective, and considerable options.
Throttle response is good. It actually seems to be about 1psi of boost at 60. I have good response at pretty much any speed other than off-idle....and even that isn't horrible.I see your steady state 60 mph no boost how is throttle response from there?
The inability to pump fuel up top appears to be a tune issue but could also be the DS4 limit. I'm curious about the DS4 Merlin pump and how it can put out more fuel up top.
Your DB2 move is perhaps the best way to go for fuel needs.
I had adjusted my fly by wire pedal as it wasn't going all the way to the floor and I have the same fueling issue up top however I suspect the tune up top more than anything as Heath used a DS4 on his 500 HP build.Throttle response is good. It actually seems to be about 1psi of boost at 60. I have good response at pretty much any speed other than off-idle....and even that isn't horrible.
Any other specific videos that would be good documentation?
The new wheels aren't on yet, this is the baseline before I put the new wheels on. I still have the 64x76 12 blade turbine and 60x82 8 blade compressor wheel on right now. I'm hoping to swap the cartridge later this week.I had adjusted my fly by wire pedal as it wasn't going all the way to the floor and I have the same fueling issue up top however I suspect the tune up top more than anything as Heath used a DS4 on his 500 HP build.
I see your acceleration is like mine very quick. There is way more mass air flow for sure than you had with the GM8 at higher psi levels those wheels jou installed just made that better.
I'll see if I can hook some pre and post gauges up later this year. But having said that I feel very confident that I have very little pressure loss across the IC. The reason I say that is because the pressure the gauge is reading at the intake plenum didn't change from before I had the intercooler to after I installed the intercooler. Of course that could just mean that the intercooler and the stock upper intake have the same amount of restriction. Gauges will tell the story.Be curious to know PSI pre/post water cooled I/C.
It figures I see now you commented at the end of post #92 my bad.The new wheels aren't on yet, this is the baseline before I put the new wheels on. I still have the 64x76 12 blade turbine and 60x82 8 blade compressor wheel on right now. I'm hoping to swap the cartridge later this week.
