Jorge6.5
I love how you customized your down pipe to accommodate the exhaust from the waste gate. That has got to help.
Your addicted now for sure, the HX40 IMHO is best suited for the 6.5td.In keeping with the theme, here is another crappy video (it's starting to become my specialty, ha!). This was a quick vid I took on the way back to work during my lunch today. I tried powerbraking for a second to build a little boost but then the tires spun (you can see this on the tach when the rpm goes up at first, then back down). So I'm not sure that I really had much boost going when I took off. I'll try to get some better videos up in the future.
Again, it isn't a rocket, but it's better than it was....especially at highway speeds. It's nice flooring it on the highway and it actually moves when the rpm goes up, rather than just making a bunch of noise, but not much happening. Once the new engine is built, and I get a tune for the HX40, then I'll turn the boost up and enjoy this thing a bit more. I am pretty pleased with the current state, knowing that it's only going to get better.
Wow Nate, that Tahoe will flat boogy! After seeing that video, I don't think I would want to be in the lane next to you! I'm thinking, I'd still need more fuel, and maybe some water/meth before I would want to face off against that beast! Very Nice.
Matt
Is that a p400 calling to you?
Thanks SS!! First off, your truck is awesome and because of you I strongly considered an HX35 for a while. I will get it weighed in the next couple days and post the results.
Yeah, the way yours comes out of the hole is what impressed me! And yeah, your combo is a bit different, so I looked at other combinations people had and decided I would go the HX40 direction. So far I'm not displeased with the results, but all I have to compare it to is the GM8.I love my HX35 but do notice that it runs a little high on cruising boost. A few pounds higher than what I would like. But After looking at how your truck moves I might want to go with the bigger hx40. I have also had an offer to try the ATT and I wonder if it would suit me better. My setup is different than most others with my gear ratio being 4.56 (for the 37 inch tires at the time, now running 35's). Im thinking of changing back to either the 3.73 or go to a 4.10. My truck is quick off the line but top end and cruising my RPM is a little high and lacking.
Thanks! Yeah I thought it would help.
