- Staff
- #341
Really looking good and taking shape. I bet you look forward to trying it out after it is finished.
Thank You! Yes, I do! :thumbsup:
:email11: Finally got those HID adapter mailed last night.
great work again,,but have you thought about buying a bigger truck?,maybe a c6500,i think your duallys getting to its weight limit,with all your improvements
No stickies yet, but thats a good idea.
I got the adapters, once I figure out how to install them I will take some pictures and add it to this thread. Thank You! :thumbsup:
Basicaly just glue them to whatever you want light coming from. Could make a hellacious porch light:rolleyes5:
It might be worthwhile to look into reflective mylar faced bubble wrap. I've seen it used as a thermal duct covering for AC ducts. Duct tape it to all five hidden sides of the fridge.
From orbit on my Android.
For the fridge make sure the condenser is within a 1/2" fro mthe rear wall when it is installed. Alot of cooling problems come back to the fridge being installed with improper clearances. If there is to much clearance from the condenser to the rear wall, it won't get a good thermocline effect. Also while you have it out, pull the flew apart and clean the soot out. There is a deflector that goes into the burner tube from the top down, and it is easiest to pull out and clean with the fridge out.
