- Staff
- #301
I measured the distance for the tie down hook. Then I removed it. Last time I used the camper it felt like this tie down hook was going to pull right out. Know I see why. It was not held on by much. All the wood around it was pretty rotted. The 4 screws were very rusty along with the bracket.
As I was installing the plastic over the fridge hole I stepped on the wood and caused most of the damage. I then pulled threw the 12v wires and removed the plastic plug. I played around with the propane line but the wind is getting bad from the rainy weather. I will play around some tomorrow.
Here is the plastic, aka black trash bags stapled and taped up.
I will probably have to add some wood to support the plastic.
