- Staff
- #321
I'm tearing into mine today too. My right rear jack is loose and I'm not sure whether there's wood damage there and can't get to the area very well because of how the shower stall sits in there so am going to pull the skin on the right side and check everything out. I pulled the windows and doors on the left side a couple of years ago to reseal everything and all the wood on that side looked like new but the guy I bought the camper from had just done the right side dinette window. He said the wood on that side was good and had pictures where he had replaced the bottom part of the wood frame at the bottom of the dinette window. He hadn't pulled the skin though and just cut out the inside paneling along the back of the dinette. I like pulling the outside skin since it's just some screws and staples and allows me to reseal everything as good or better than new. As you can see on your project, sealing these things regularly is probably the most important maintenance step there is. I run new caulk around the windows, door and fixtures every year and if the original caulk (the flat, grey putty stuff that comes in rolls - can't remember what it's called at the moment) has hardened I pull the window or door, clean it up, and replace it with new. After I put the window or whatever back in I run a plastic putty knife or plastic picnic knife around it to trim the putty even with the window frame and then run a bead of good quality mildew resistant exterior caulk. I can pull everything on a 8 or 10 foot camper in about 2 hours but cleaning the old putty takes me a good 4 hours, then another couple of hours reinstalling. I usually wait until the next day to run the beads of caulk.
Campers require a ton of upkeep, 97% of owners never do it. Then they are appalled why their camper leaked rain all over the place. In my opinion, if you can afford it, all campers when not in use should have a roof over there head. Wish you luck on what ever you decide to do with your camper. :agreed:
