- Staff
- #361
Alot of manufacturers screwed the pooch when they built the fridge box. Sometimes you need to build a baffle to go between the condenser and the wall to close up the gap, or install fans.
I could add but, really do not know how I would give it more space. I will measure it up soon.
The problem is that many give the fridge to much space between the condenser and the wall behind it. If it isn't a close fit between the condenser and the wall behind it, you lose the thermocline effect that causes airflow across the condenser. When the fridge box is built correctly, you will feel an actual draft going through the fridge area and out the vent up top. It will feel like a fan running. If there is to much space the air won't get hot enough coming off of the condenser, and you won't get the natural thermocline to cause airflow.
I use a small computer fan to blow air across the condensers to keep the air flowing. Sometimes I get ice in my fridge. That is how cold they can get when cooled properly.
Marty, when you are finished with this rebuild, you should consider sending a copy of this thread on a CD to the original manufacturer of that camper shell to show them what you did and how you went about it. I bet they would be very interested. Maybe even make you an unpaid consultant. LOL
Ut oh. As long as the wood can get dried out, you should be fine. Wood rots when it is under constant moisture and cannot dry out. I hope you make out OK down there Marty. I saw the storms and tornadoes on the news.
Yikes. Those things are so scary. Glad to hear you and your family are OK.
Only 113 pounds, that aint to bad. My HONDA EU3000IS weighs about 160 with fuel in it. It's a HEAVY SOB to get loaded up by myself.
This one runs on propane, I have another one just like it that runs on gas. The gas one needs a new carb.
I figured out the bolt. It is a 3/8" with a 16 pitch. I already have a tap for it. I will just have to purchase a new bolt.
That's why they call it a project! :lmao:
good luck ,keep us posted
