I guess getting parts machined out of stronger metals like titanium or something would be too expensive huh? And at that point maybe machining a different pump mounting configuration and using a better pump would be cheaper, not cheap but maybe cheaper, just brain storming. Is there a 8 cylinder P Pump made?The hole cant be opened up because it has to seal transfer pump pressure internally in the piston for the timing advance to work
There is a larger pin available that was used in the DB4 AG pumps. But it takes some machine work to make it work other than opening up the can ring and advance piston. The "automotive" DB2 cam pin has a groove machined into it for transfer pump pressure to flow into the cam pin which pushes on the advance servo to direct TP pressure to the back of the advance piston to change timing. So no only does the groove need to be added, but the advance piston and cam ring will need to be opened up at an offset as to no mess up the passages the advance servo controls. The hole needs to be very precise so there is no loss of transfer pump pressure as well as the advance passage would be extremely close to the large hole required for the larger pin. Its doable but i have to find a EDM shop wiling to do such a small project.
