Rockabillyrat
SlIgHtLy StUpId.
The reason timing gets locked on HO DB2s is to take stress off the cam pin. The added load on the pin from a modified pump combined with the variable advance servo piston spring tension from the LLA armature. Can be too much back and forth stress on the cam pin and they tend to break.
By redesigning the advance system and cryo treating the cam pin im hoping I can keep a functioning advance system on a HO pump. But an all out race pump with big plungers like a .370 will still require locked timing because its so much added stress even the input shaft needs upgraded. So the cam pin stands no chance. If the larger discontinued 4 plunger marine pump advance piston and pin where still available then maybe I could make one work with a functional advance. But those parts are obsolete and unavailable
