perfect. rebuild or drop in?Hey Deejaaa, I bought another 4bd2 yesterday. Its coming from NY for $975 shipped.
was until i looked at the picture. love it when a plan comes together................Confused??
Keeping at it.
Im going to relocate the batteries. That gave me space to run the stock Isuzu air filter. This thing is huge AND! it will allow me to modify it for a "true cold air intake"
First I had to lower the battery tray. I cut a good 2" out of it.
Next used body hammers to reshape the inner fender at the point the tray bolted to. This lowered it to match the other side.
Cut the Isuzu inlet off. Actually drilled the spot welds out.
Fitment looks pretty good and the hood closes.
Well I asked my brother. He says its possible, but without knowing the specs on the alt it could be dangerous to your system.
Why do you want more voltage?
I'd just like to have it closer to 13-14 after everything is warmed up instead of barely 12
What's this on? Have you checked to see what it actually is at the battery? I know the 94 and older guages read pretty low VS actual voltage. Depending on your alternator, it could be a bad regulator. I have a reman alternator from ADVANCE on my old JEEP and it will barely hold 13 volts when hot with no load. The AZ one I had before it would hold 13.5, and the stocker held 14.2 before it died.
