Yes, in a couple pics above you can see the allignment.
Im going to start on the alt today as its supossed to rain all day.
why is there a drain on the starter?...................orinents the drain tube downward.
A good thing worked out for me today. I was able to get ahold of a 22SI alt and fit it up today. The 22SI is much more common and available in higher amperages and also come with the tach output.
The alt is physicaly big and the mounting points were simular enough to use the stock Isuzu bracket I just had to come up with some spacers and bolts. The alt has 2 belts. What is strange is the water pump is driven by three belts two share the alt and the third is dedicated with its own idler pulley. I guess Isuzu wanted to make sure the water pump worked.
I tried every alt I own as you can see the pile at the bottom of the pic.
Im planning at this point to remote mount the turbo to the pass side
View attachment 30589View attachment 30590
Couple more of A/C brackets
View attachment 30591View attachment 30592
I thought all delco alternators had the remote sense connection so I just looked and it is optional on the 22si
http://www.google.com/url?sa=t&rct=...eXhLxR&usg=AFQjCNEMEm5j9kFGwtDf_f51T6rL6soK5A
