buddy
Active Member
It sounds to me like a bad PCM or one of those slight compatability issues. To try to get a handle on something like this I started snipping ground and power (battery and ignition) wires to the PCM and couldnt get this kind of fault where the SES works but something else doesnt. It was all or nothing. However, it only needed one of the two grounds to run. And my SES light also kind of flickers a little sometimes but starts every time. Now, I had experienced a case where an incompatable program would light the SES light but not glow or start the truck. in my case the only program I have found that wont work in my truck is a program for the DS4 5068 IP.
I would try another PCM for a while to see if that eliminates the issue. Your OBD2 could be more dependent on the two ground wires or a lot more sensitive to power/ground issues.
