That would work. Scared to grind on a perfectly good wrench?![]()
I don't even hesitate:smash::crazy::idea: They make new wrenches every day
I don't even hesitate:smash::crazy::idea: They make new wrenches every day![]()
X2 you gotta do what you gotta do, I've even got some "custom" Snap On tools/wrenches field modified to work in places the turbine designers forgot to provide tool clearance for. No warranty of course after that but they get the job done where no other tool will work.
Ignition switch
It ain't always the grounds playing tricks on ye,it could be power supply as well.
Batt to fuse box thin red cable could've worked loose or can be corroded at the stud.
or a burned or corroded wire or fuse terminal at the box.
Ign switch is a good candidate though.
I had a 'simular' deal with mine once. It was one of the connectors on the ECM itself. The pink one IIRC. One of the wire ends that are supposed to lock into the plug broken the little tab thing off so it wouldnt stay in. Not the whole plug just the one stupid wire, but it just so happened to be the damn power feed for the ECM. Kinda hard to find that one, you have to take out the glove box and wrangle the ecm out to see anything. Those ends might be hard to find if you need to crimp on a new one. I got lucky my uncle retired from Packard Electric and he had one in his tool box. Maybe Terminal Supply would have them if you need to go that route. Hope this helps.
I would pull the puter out and leave it loose. next time it happens you can carefully wiggle things to pin point it.
