buddy
Active Member
No problem. I was confused when looking at the diagrams and you mentioned the Glow Plug fuse, which is like the OBD1 trucks, and I have AllData access for 96 trucks.
Dave had a good suggestion that you might want to check and make sure the Glow PLug signal wire from the PCM to the controller is not shorted to ground. Or the glow controller isnt shorting it out somehow. Maybe if its shorted it causes this issue. I figure that shouldnt cause a problem, because the PCM would have some line protection, but maybe that protection is to shut down. The PCM itself probably puts it to ground when not triggering the controller. So you could disconnect the PCM harness and check those pins to ground, see if you can get a real low resistance reading. If you leave it connected to the controller there will be some resistance to ground, I will go measure it later tonight maybe.
This goes beyond a glow system problem. Its possible the glow circuit has something to do with it. Anyone with a WTS issue might immediately jump to the glow controller, but the real problem is the PCM isnt powering up correctly.
