Brooklyn Tow
9 11 Never Forget
Any update Louis?????????
Well now I'll run and it seems that when I do stall, it's only while at "Idle".......So I'll, pop the hood, jump out with my 15mm ratchet, loosen the nut on the "intake" stud, where all 3 grounds are now, stacked up with washers in between, swivel the eyelets (without removing any), tighten the nut back up and she'll fire. So far, like I said this is only at "Idle".
Mind you, Still haven't fixed the broken ground strap from the tranny dip stud and when I do........I'm gonna take out the stud, shine it up to a mirror like finish and return that ground to it's original location......I'm not liking the 3 stacked grounds on that 1 intake stud. Also that stud and it's surrounding area (don't know if that one comes out) need/will be de-greased and wire brushed (AGAIN) and I will add another Braided strap from the dip stud to the intake stud. I found the exact matching strap in AZ help section, so I will be changing the 2 OEM frame to firewall - firewall to dip stud and adding - dip stud to intake stud.
Also, I now need to extend the ground wires from all the snipping and changing eyelets, I'll need to find an expert in soldering, as I have never even held a soldering iron.......and I hear their is a skill factor involved. ( I would cut and crimp the extensions in, but I feel the connectors are inferior to a good solder connection)
If you haven't replaced the ignition switch yet, I'd go ahead and do that. It was the last thing I did to the 96 Suburban to put the WTS ghost at bay.
If this don't work, that'll be my next move......BUT, I know it's these friggin ground wires because, when I stall, the PCM looses it's power/memory......There is a SES light on (From a boost code) and every time the Ghost appears, the SES light is out till next key cycle.
Also, "Simon says"(LOL)
