HX40II Turbo Install
I was wondering the same thing about the testing of the ATT
all it takes is A Ateam to arrive at my door, I just towed from NC to Ohio on 77 today, pretty much all mountains from VA North, I could maintain 55 on the worst grades EGTs hit 1150, 3rd Gear on the long pulls, Plenty good for me about 200% better than stock setup, The Turbo Controller I made is working very well about 4 Psi on the level tops out at 18 Psi, I put a softer spring in it before this trip
Hey Bruce, is that 4psi on the level with a big trailer behind you? Thats really good. What kind of speeds and RPMs would that be at.
Yes thats towing 11k 5th wheel Im pretty happy with the controller set up as is, thats about 2200 rpm 63-65 mph, I filled up here in Ohio 286 miles 25.1 gals 11.3 mpg all mountains, not too shaby
Those are SERIOUS hills in there. Good numbers for those kind of roads!
a couple times I had to slow down to about 40 because of slow Semis but was able to gain back to about 50+mph and pass them when traffic cleared, I had alittle left but didnt want to push the EGTs too high, I was able to go by a newer Powerstroke with a similar trailer by Fancy Gap I told the Wife to get the camera out but she wasnt quick enough lol
Maybe he took a pic of the crazy guy with the 6.5 passing him?:thumbsup:
I've said it before, these trucks when modified right are capable of pulling a load as well as some of the modern stuff. That is, within our actual weight capability.
That's what I do, look for the 'nostrils' then bend an ear to hear the rattle and turbo.. :thumbsup:
What are the odds of seeing a TTS member from NC driving through my old stompin' grounds? (Better than the MegaMillion lotto for sure)
That's awesome that you saw me wave, I was headed into that blind underpass so I was looking 'that way' so I didn't see you wave- but that's ok!
Quick go buy a lottery ticket...
Im Going to order the hx40wii on monday, i just wanted to make sure before i buy it that no one has had anyproblems with this turbo or had a problem with their engine after they installed the turbo, i plan on setting the waste gate at 15 psi do you think my engine should handle it fine, it has like 250,000 miles, oil is black, and i run synthetic oil and change it every 3000 miles.
15 is just a touch higher than I would run it on a 250,000 mile rotating assembly....
You will be fine at 15 psi, I havent heard of anyone's turbo taking a crap yet, Your engine will love it
