Chevy3500
Will the waste gate go down to 15 psi on the hx40wii and racedaymechanic, i will also be buying your down pipe soon
One fine point I don't think I have seen anyone make is. Before you fire up the engine with a new or R&R turbo you need to (while the GP's or injectors are out is best) turn over the engine till the air is purged out of the turbos oil feed line and you have flow out of the drain. Spinning a turbo without that oil film it runs on will severely shorten the bearing life.
.... i just wanted to make sure before i buy it that no one has had anyproblems with this turbo...
Not like GM or Navastar ever :rolleyes5: had a porous casting. :hihi: 'but your point is well seen'Just ran across this:........Every production run has a few clunkers, so take it for what it's worth......
... ching-a-ling-ying-yang-a-ding-dong factory GEP tried to get optimiser castings from....
They were/are. In one of the long posts here about the Optimiser and P400 one of the inside GEP sources said they tried to source Chinese castings but while they could made nice castings they had QA issues so they didn't go with them. And no I am not going to hunt down the posting.Got a reference to back that statement up? Everyone I've talked to has said navistar was the original contractor from the get go....
They can reverse engineer anything, then build it way cheaper than we canThey were/are. In one of the long posts here about the Optimiser and P400 one of the inside GEP sources said they tried to source Chinese castings but while they could made nice castings they had QA issues so they didn't go with them. And no I am not going to hunt down the posting.
Bet ya dollars to donuts that attempt is where the Chinese castings we see now came from. They had the GEP prototypes so run with it. It happened to GE when I worked there years ago. We let them look at a design and then did not for what ever reason contract with them to build it. About a year later some one was selling a product based on that same design.
Good observation. That would stand to reason considering the heads and blocks are highly likely to be poured from the same pot feeding tandem casting lines. And "according to rumors one might find on the internet"I can't say about what is in the metal, but I can tell you that the GEP heads I have and are porting on are a harder metal than the older GM heads are, it takes more work to port them just due to the hardness of the metal, and the funny thing is that the runners are a little smaller in the GEP heads, meaning there is more to take out to get the same size runner in to the GEP head.
Chris
Political motivation is a good point. Maybe sell the offshore blocks to GM and the Navastar ones to Uncle Sam...
Chris
The smiley faceNot to be confrontational but nope. I've got a GM sourced GEP Optimizer 6500 in my truck. It's an Optimizer 6500, Navistar cast. Guaranteed.![]()
The smiley facein that comment was meant to indicate I was joking. That was never meant to indicate GEP ever used any casting from any place other than navistar. :rolleyes5:
There were comments repeated, supposedly from insiders, real or not, that at some point GEP considered other sources maybe even china. :skep:
That last emoticon was to indicate, even I am skeptical.
Explaining your emoticons kinda kills the fun/point of using them.![]()
Im Going to order the hx40wii on monday, i just wanted to make sure before i buy it that no one has had anyproblems with this turbo or had a problem with their engine after they installed the turbo, i plan on setting the waste gate at 15 psi do you think my engine should handle it fine, it has like 250,000 miles, oil is black, and i run synthetic oil and change it every 3000 miles.
