Edzzed
You should team up with an arsonist.about 10 different teams, I just go and put out fires now, Its working out pretty good so far
Sounds like good work if you can keep the flow up. With this fuel injection they are using now I wonder if they need a software guyI have, every team has Issues, the smaller ones who don't have a Electrical guy call me
Just want to throw this out there, but on my gm-8 the boost controler I made is very touchy with the temp changes. Between hot summer air and cool winter air I always have to adjust mine..... does anyone else experience this.... I don't want to put on a new charger and be dealing with a damn spring all the time????
Maybe but the waste gate arm is straight up and down and swings to the rear of the truck to open, you would have to rig up a arm for the waste gateLooks pretty good. let us know if it also lowers your cruise boost, like if the wastegate is opening at all at low load high speed cruising.
Do you think its feasible to abandon the existing actuator holder, and just make a bracket that goes to some of the forward most holes, so it prevents interference with the larger air boxes?
Good way to get exposure all around as well as get a feel for who you like working with more should your service be needed full time in the future.about 10 different teams, I just go and put out fires now, Its working out pretty good so far
Speaking of unique .. has anybody thought of building a 'radial' spring wastegate control, rather than a longitudinal one? (using the torque in the spring rather than the compression?)
