Where can one of those springs be had from?
Use a tube cutter. There will not be any shavings that way.If you cut the drain pipe, would the metal shaving go down to the oil? How to avoid getting metal shaving down to the oil pan or trap inside the pipe?
you said that it chokes still on the 6.5l? when you installed it did you pull out the OEM down pipe and replace it as well?
4inch diamond eye exhaust installed less than 500 miles after I owned the truck. Seems to be a 3inch downpipe into a 4inch system.
i was just curious if it was still the crushed OEM downpipe... it is a piece of restrictive crap.... do you agree? some places it is crushed down to 2.5"....
I believe Bruce was working on a TM for this turbo too. Any progress with that?
BTW, I got the turbo installed and things are looking good so far.
Who you with now Bruce?I've been busy with Nascar stuff for the last week
about 10 different teams, I just go and put out fires now, Its working out pretty good so farWho you with now Bruce?
