Acesneights1
Just antiseize everything.
I used grade 8.8 cause it was all I could find. I may change them later.
Heard/read somewhere that a stainless bolt can't take as much torque as a grade 10.9 bolt. Can't remember where i heard/read it. Don't know if it is true or not either. Any manifold bolts i've ever done have been slathered with 2000*F+ Copper anti-seize and i use grade 10.9 bolts. I used grade 12.9 allen head bolts in my blazer for the two exhaust manifold bolts that were missing when i bought it.
I was under the impression that in ex manifolds ss bolts have a tendency to shear off when removing them. Now i always use never-sieze anyways, but i fear that with the high temperatures, it really dosent do anything after it burns off. Is there a high-temp never sieze available?
YOu quoted IAMDAVE saying he uses 2000 degree copper anti-sieze. If you plan on running your manifolds over 2000 degrees, you'll probably have other issues to worry about besides removing the bolts![]()
Kenny have you priced out simulators or are you waiting for used set to pop up?
I'd really like a set too. On CL there is a place that sells them for 150 new. Thats not bad at all.
The true beauty of the simulators is you can rotate all your tires around. Painting the frontside and the backside of all 6 tires is just a task n a half...
Good call.........haha didnt really think about the temp rating he put in. Answers my question
I have no idea who carries it as i got the two bottles from a friend of mine, but it's never burned off anything i've put it on. It's on my injectors, glowplugs, exhaust manifold studs, t-stat housing bolts. It's everywhere. ):h
The Anti-seize i use is made by Steelman/Versachem(although my bottles say Steelman on the top).
