This comes back right away. Not even able to cycle the key But no solenoid B nowThe pause between turning the ignition on and off must be at least 40 seconds.
This TCM that’s hooked up now come out of his running truck until the motor blewWhen you measured the voltage at solenoid A, it was about 4 volts. but it should be about 7 volts. Are you sure that the TCM is 100% functional?
Internal. Harness. Brand newAre the connector contacts to the gearbox oxidized?
External plug looks okay
Not sure how to upload the videoCan you insert the probes into the solenoid A connector, turn on the ignition and move the all wiring harness and connectors, and observe the multimeter readings?
upload to youtube then post the link to it here.Not sure how to upload the video
Internal harness is new.I feel like you have some loose contacts in the plug, ether on the truck harness side or on the trans side. moving it around and seeing a fluctuation from 4 to 6 up to 11 volts
Denta is the more knowledgeable person here, but I wonder if the internal harness that was installed might be of the chineesium variety. I'm curious if there would be a way to just slightly tighten up the contacts in the connector and try measuring again. if not, it's possibly gonna be firing the parts cannon at a new internal harness or the main harness pigtail connector or possibly both!
Will have to get a better picture when it stops raining nowCan you post a better photo of the connector ends? I'm looking at the harness side and from the photo, it actually looks like three of the pins were replaced at some point. they look different than the rest.
on the trans side, I can't really make much out as it's dark. maybe try turning on your flash for the camera.
I really feel like there might be an issue in this connector with your voltage changing. I assume your were moving this connector with the meter on the solenoid.
