Jaryd
Extremely Deplorable
The links not working for me. It says sorry can’t find the page.
Yeah, you have to have a 97 to access the infoThe links not working for me. It says sorry can’t find the page.
Wow none of those worked for me
x2, guess that's why Nate is having trouble finding his part
Tonight was pretty frustrating. First thing I did since I was pretty sure I’d have to do a few set ups was create a set of setup bearings. I ground the inside of the old pinion bearings so I could slide them off and on to change shims without using the bearing puller. That wasn’t a big deal.....well except for the dremel frying. Grrr. Luckily I have a cordless one for backup.
So then I started setting up the gears again. I’m having a really hard time seeing the pattern on the gears. I read a thread today talking about making the marking compound the consistency of chocolate syrup by adding some gear oil. Nope, that didn’t help either. I’m starting to think it’s because the gears are used and worn in. Not sure yet if that’s going to be a problem or not. I tried a couple different pinion shims and the results are still inconclusive. I’ll try some more tomorrow.
I've tried more. I've tried less. I feel like what's going on here is that because these are used gears......with who knows how many miles......they are really worn into each other. Because of that, more of the face of the gears is contacting each other so it's wiping the compound off of pretty much the whole tooth. That's my theory. I can kind see a contact point, but it's really wiping almost all of the compound off. It isn't like when I set up the new gears 2 years ago.I wonder if less compound would be better
Maybe........ though from the reading I've done it seems that most people that have tried both had better luck with the yellow stuff than the Prussian Blue.Is prussian blue something that would work here?
https://www.permatex.com/products/s...epair/rebuilders-aids/permatex-prussian-blue/
That makes sense. I wondered about that - needing more backlash to replicate how the gears would have worn. 2 problems: 1 - I don’t have the set up tools and 2 - the pinion isn’t stamped with any numbers....which seemed weird to me. Thanks for the info.With used gears you need to loosen up your backlash to the .010-.013 range in my experience. I've also found with used gears it is best to use the set up tools, find your zero pinion depth with the depth guage, add or subtract the amount stamped on the pinion, put it together, set the backlash to .010-.012, and let it roll.
That’s cool! Would they run them with the cover open? If so, how did they keep them from burning up?At a gear and driveline shop I went to years ago, a shop had a 240v motor that they hooked up to problem axles to run for noise testing. No clue how to
Deal with that gear problem other than write a check to a pro.
