jrsavoie
Recruit
While you were cranking to get fuel instead of properly bleeding as was suggested you probably sucked air into the Injection pump.
This makes these things hard to start even when they have a clean recent history.
If you keep cranking this thing unnecessarily you're going to kill your starter or at the least it will lead to a premature death.
There is a reason it was suggested you hot wire the lift pump. If you read the stickies about testing the lift pump I'm prettyy sure it doesn't say anything about cranking the engine on an empty filter bowl. Where do you suppose the air from the bowl that didn't come out the bleeder went?
