Fireman469
If you read a lil further back he said the previous owner used either to start it fairly often.
My bad, its a 1/4 inch line not a 1/3 inch line I meant to say which is gonna cost at most a cpl bucks. again it will demonstate if the IP is at least pushing any fuel through
I agree about the GP's its easier to do them through the wheel (#8 sometimes from the bottem) to change them. That said I would use a piece of wire several feet long to connect on the end of each wire (unless you can somehow get it to connect to the main harness connector) and run it to the cab to see if there is any power running to the Gp's. A common problem especially on the turbo side was the wires became brittle and break as they run so close to the maniflolds. Another good reason to take the wheel well off to allow for easier inspection. Always start with the Gp closest to the tranny as sometimes there will be only one or two lines to feed all gp's on the same side.
I do like the idea of someone extra here to hold and get the beer, dont foregt to have the Mrs handy as well to be able to run and get beer as needed
