avoid buying used but tested.
Read more on this forum or at the place. Just say NO to that opperation. Buy a Standyne from PMD Cable.
What have you done since the last time you posted?
It was running til you shut it off, With these temps you could be jelling if it still has summer diesel in it.
Did you add treated fuel?
You have to watch the weather with a diesel.
Did you try WD40 or similar with the truck pluggged in and spraying while cranking?
I would at a minumum purchase the extension cable from PMDcable.com and he has a nice larger heatsink. You can find new PMDs online for less than $200, or just get a whole kit with a new PMD.
With the Electronic Fuel Injection at stake I don't trust just anyone making cables, they have to be good and I know the ones from PMDcable.com are. He can even make one with the right gold pins contacting the new Grey Stanadynes if you go that route.
Pensacola Diesel sell new PMDs the cheapest I think, but I wouldnt get the cable from them.
I'd plug the truck in for at least 3 hours in this temperature before I tried misting with WD40 diesel or whatever.
Don't forget to hotwire the lift pump while trying to start.
Do you have a 2 way or 3 way so you can plug the battery charger and block heater in at the same time?
How much fuel do you have in the tank now?
I doubt you are having PMD issues as you never had any PMD symptoms while the truck was running. Did the previous owner have PMD symptoms?
If you pulled the PMD off or had an extension you could test to see if the PMD was outputting enough voltage to start the truck, using a multimeter.
The big problem I'm having now is I'm broke till I get it fixed. I have to borrow the money, so anything over $100 is out of my range. I have to go as cheap as I can, I just don't want to trash the truck with parts that are too cheap. At this point I'm beginning to consider selling it and getting something else. I really don't want to because I like the truck, but I'm starting to run out of options. I can't work without a truck, so right now I'm between a rock and a hard place.
Semi trucks when they freeze up, use to take charcoal and light a fire underneath the fuel tank. Check to make sure there aren't any leaks. If you have an old metal oil drain pan you can light the fire away from the truck and slide it under after it has burned down to coals. Slide it under the truck and throw a blanket over that side of the truck to cut down on the wind. (MAKE SURE THERE AREN'T ANY LEAKS, AND DON'T LET THE BLANKET CATCH ON FIRE!!!) It works, you just have to be safe about it. A little gas before the turbo is a better ignition, not to much, a couple of drops. WD40 is a better lubricator but if you don't have it, gas will work. Drove tow trucks for years and had to thaw out fuel tanks all the time.
Ummm the 6.5 generally doesn't succumb to needing "thawed", fire is a little drastic If fuel is gelled to point it won't make it through the filter manager maybe this might be necessary if no other means of heating fuel were available.
He can try to test lift pump (required for proper IP priming) via the lift pump troubleshooting in reference sticky, and see if fuel is at least making it to the IP, if it's making it to there, then he can drain the filter manager about 1/2 way or so, remove the top of the filter manager and fill with some 911 fuel treatment/anti gell if gelling is the issue that should get him started, gas on a rag not good idea for these engines, WD-40 is better, also hot air from a hair dryer works as well.
Winter time brings out battery & gnd issues.
If the Fuel Shutoff Solenoid was bad you would normally get the DTC13. But if you want to eliminate that possibility you can pull it off and with a snap ring pliers remove the plunger so it cannot impede fuel flow.
A PMD relocation is in order, and will enable you to more easily test to see if it is properly commanding fuel injection. With no trouble codes reporting its likely a PMD or mechanical IP problem.
