I figure it weighs aprox.1600lbs.WOW!That's a good chunk of metal!
Will you put the parts back in the same way?
The crossover pipe came from Warpspeed. They have a store on ebay. The tube is 2 1/2"! The manifolds are 2 1/4". That's why it's necked down for the flange and bell. It was about $80 with shipping. I just looked and didn't see it in their store.Where'd you get the X-over Barry?
I washed it all down with lacquer thinner and then sprayed it with rustoleum rusty metal primer,2 coats. Then 2 coats of rustoleum gloss black.
Yep, it sucks! I wire wheeled everything then washed with lacquer thinner by handThat must've taken some time. When you say "washed", do mean with a spray bottle? And then wiping everything down by hand?
I have to do something similar this week, and really, REALLY not looking forward to it.
The engine/trans/transfer case should be going back in sometime this week. Yes I plan on driving it.Sure looks good. Do you ever plan on putting these things on the road?
When you mean clean the rotors with 4" grinder, do you smooth them out by hand instead of turning them? Should go CERAMIC pads no rusting dust. I love them they last a LONG LONG time, yet do less ROTOR wear.
