Matt Bachand
Depends on the 6.5
My sig tells the story. Got 3 trucks that need engines and maybe a 4th. .
Ya know, they say an ounce of prevention is worth a pound of cure
Took a couple pics of the boxes of spare painted parts. There's 4 sets of valve covers in the valve cover box.:rolleyes5:
I'm looking at the powdercoating set-ups. It will cost around $1000Wouldn't be worth of it powdercoating the parts ?
The blown up trucks in my sig were bought that way. I haven't even so much as blown a head gasket in a 6.2 or 6.5. I did blow a head gasket in my 5.7 olds diesel engine when it hadYa know, they say an ounce of prevention is worth a pound of cure![]()
The paint i'm using is duplicolor engine paint with ceramic. The primer is duplicolor engine primer. The exhaust manifolds are :duplicolor High Heat primer and High heat paint. Everything except the exhaust manifolds has a minimum of 2 coats of clear on top of the color. I can't say about the durabulity of the duplicolor paint yet because I haven't run one with it very long yet. I'm shure the exhaust will need repainting in a few years. All the brackets, pulleys and manifolds were blasted with aluminum oxide before paint.I'm curious about what primer you're using. Does it hold up under the heat over time?
And the color coat? I ask because I just paid some crazy dollars for the Alpine green (Volvo diesel) spray bombs at my local truck center.
Dang that sucks! Sorry to hear, it looked good though.
The engine with the 2 piece crank is the one that was in the truck when I bought it. The PO said it had a "rod knock". The pretty one is the replacement. I just wanted to hear the "rod knock" for myself. Broken flexplates are mistaken for rod knocks. Hoping I can salvage the heads off the old engine.Dang that sucks! Sorry to hear, it looked good though.
Yep. That's how I get the hood off by myself. I had to put the foam pad on the boom to prevent any unwanted dents/scratches.:thumbsup: It works great!Is that your way of removing a hood by yourself?? I'm a loner worker also, I like your style! I wouldn't trust any helpers around those top secret code named "ALPINE" blocks either... They gonna re-invent the 6.5!
I got the rear driveshaft,exhaust, oil cooler lines, engine mounts and tranny mount off. I'm taking the engine-trans and transfer case all out because of a leaking seal between the tranny and transfer case that really overfilled the transfer case. This is a very heavy piece to lift with a engine hoist. The other problem is being able to lift high enough to clear the core support. My home made hoist is up to the task. It will lift to almost 10 ft. I did this before with a truck I junked ,so I know for shure it works :thumbsup: A load leveler is a must have to tip the engine to clear obsticles . Less than a hour and it is out.
Lots of cleaning and painting to do now![]()
