Paveltolz
Доверяй, но проверяй
You could try studs and nuts. Can’t remember the length and size (M6?) since they have worked well on mine for the past 11 years.  Just had to insert the studs at the front after you’ve laid the pan down as the angle makes laying the pan on evenly a non-starter otherwise. Could always use the bolts ton the front though. Would ensure you don’t have interference with the HB…pretty tight clearances.  Just a thought.
