jrsavoie
Recruit
It doesn't look complicated.And ACE did not have.
Could you make one faster than any other option?
Other than finding a new piece and ordering it
Nice. Nice of you to share a link for the next guyAmazon.com
www.amazon.com
I looked into getting this new container to work and the only way I can get it to work is if I ditch the K47 and use a basic silicone 90 degree elbow with cone shaped air filter.Even the 92-96 flat panel air filter setup doesn’t give me the clearance I need.The OEM ones are out there but pricey. let us know how well this swap goes and what all will be involved. I would like to replace mine so I can see the coolant level.
Somehow I missed the info in this post. Thank you. I ordered them this morning. I found the bolts I did have saved after we got home but…3/8”, not M-10. I’d have screwed up and tried these out had it not been for this experience.The part number from arp for the M10 bolts is 430-3511.They fit perfectly.
Not a problem.Glad to help out anyway possible.You’ll definitely like those arp bolts the minute you attempt to install them.They fit quite snug going up into the starter housing.I put antiseize on them just to make things a little easier.Somehow I missed the info in this post. Thank you. I ordered them this morning. I found the bolts I did have saved after we got home but…3/8”, not M-10. I’d have screwed up and tried these out had it not been for this experience.
So, again, thanks for the assist.
Love this, with the exception of Hitler’s Revengereg.Cut and assembled a 6AN Turbo Oil Feed Line for BigT's new motor. Tested it to 55 PSI with soapy water at all points and no bubbles. Added the x2 NPT-6AN fittings for the motor and the turbo sides too. Otherwise, no bueno.
View attachment 89035View attachment 89036
Swapped in the ARP Starter Bolts and packed up the one I scavenged from BigT when doing the starter cross wire boogie at his place last month. Will bring it, the Turbo Oil Feed Line and the injectors I pop tested (ungood chatter and patterns on most of them) to the salt flats and, when the word comes that his new motor is delivered, will head up there from the Salt Flats.
Packed the truck for the Salt Flats. Clothes, tools, EGO batteries, etc. are in the cab.
Will be camping with Heath and a few other folks above the flats through 9 AUG (weather permitting...rain in the forecast starting Tuesday) and during the days, crewing for Mursik Racing and this little VW 1.8 TDI powered go getter. Current record for this class is 130 something. He'll break that and push it up higher.
Oh yeah, picked up this Touareg consolation gift but, not diesel. VW Atlas, gas 4banger. 270 HP and 273torque.
View attachment 89032Tow rated to 5000# but one would be really stupid to stress that little power plant for any length of time. Weighs about as much as the truck and on the first tank, got about the same MPGs (20.7 ish) but, lots of idle time trying to unscrew some of the factory settings to what we want and there's not telling if the stealership worker actually filled the tank. Still, not a bad ride.
I have a set of those jaws for the vice. And some stuff I don't even remember how to use.Love this, with the exception of Hitler’s Revengereg.
These might be for the 6.2 blocks that were standard threads, 3/8-16I have a set of those jaws for the vice. And some stuff I don't even remember how to use.
Forgot, until I saw the picture.
ARP Starter bolts 430-3511
Rest up brotha, because I'm gonna need ya.Hooked up with Bill Heath at Bonneville to crew for Flatliner Racing’s little 1.5L diesel.
Good shake out runs (no record attempts) for next event (World Finals) or next year’s Speed Week in August.
Builder/Owner/Driver with his creation. Paint Scheme inspired by 1952-53 VW “Bus”
Morning on the Salt is my favorite time
Waiting to get closer to the start line so I can do final prep and get the driver safely inserted into the car.
Salt for a hard boiled egg breakfast is easy to come by though.
Not sleeping under the stars again. It rained for short periods of time each night around 11pm to midnight for the first 4 nights with just enough wind to push my longer hair across my face…AARRGGG. I would bail out of the sack, cover up bedding with a tarp weighed down by bags and hop in the truck for 20 min. to and hour or so and then try to get back to sleep. Spent two nights in a hotel when Maggie came out with a tent for the rest of the week. I need a better tent that will last more than one night’s wind storms. Cabella’s brand was a FAIL with parts breaking on set up. Wolf Trader Cot was a fail also.
Before the windstorm on the one (and final night) of having “shelter”. Tent grommets failed and the cot’s main hinge broke. Good thing I’m an old ‘Boy Scout’ with lashing skills…at midnight…
Thursday morning (8 AUG) the owner came out and said we were done. “And there was much rejoicing” as we had three more days left. His back had finally convinced him to stop. Former Army Ranger, Red Bull Stunt Rider, High Pressure Pipe Welder etc. have taken their toll on him too.
Memorable time. It’ll seem like a good time later after the fatigue from 14 hr days outside in 100 degree heat and sleepless nights wears off.
Got a break in that department.Rest up brotha, because I'm gonna need ya.
