Jorge6.5
Can you confirm the outlet on the turbo for me please? i got to figure what im gonna need.
Are you talking about the outlet of the cold side on the hx40wII? I thought it was 3"?? If thats the case i may need to order a different reducer.
	Since your turbo has an external wastegate, will the computer still regulate the boost like the orginal one or how would that work RACEDAYMECHANIC, Im not yelling.
Racedaymechanics intake fit like a glove!!! And his oil line adapter fitting. A great value IMO and makes this conversion possible. If it were not for his parts I would have never started this project.
Any photos? I am glad to hear that you made out well! :thumbsup:
What Gauge wire did you use?Yesterdays efforts were very time consuming...
The side terminal battery connections hit the 4" 90 air intake hose, so I purchased a new pair of batteries with top post mounts. IF you use a 4"-3" 90 degree fitting off the turbo inlet, I do not think you will have a problem with a factory filter box.
I had to fabricate new battery + - cables and add some extra grounds. IMO the factory grounding locations are less than adequate and this was a good excuse to upgrade them.
One more battery cable to make and them a little custom PVC work to put in place a make shift air intake until the silicone parts arrive next week.
Stay tuned!
