Jorge6.5
Go to the first page in this thread and read on from there.
What Gauge wire did you use?
OMG time for addition...
Materials List:
Turbo $280 http://www.ebay.com/itm/120854427128?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Downpipe and Oil Fitting from RaceDayMechanic $120
Air Intake Parts from SiliconeIntakes.com $115 (FWIW RaceDayMechanic says he can provide as well for future builds)
- 1' AL Pipe
- 2.25" to 2.5" Silicone Reducer
- 2 4" 90 degree Silicone elbows
- T-Bolt clamp 2.25"
- T-Bolt clamp 2.5"
- 5 T-Bolt clamp 4"
K&N Universal Performance Air Filter RE-0870 from Amazon.com $41
Turbo mounting bolts (4), washers (8), lock washers (4), and nuts (4) for 1" longer than stock bolts est $10 at Home Depot (I had some laying around already)
6" 3/4" ID rubber hose for the oil drain pipe extension est $5 (I had some laying around already)
2 Duralast Gold Batteries 34DT-DLG $230 (you could choose to just change one and save $)
0/1 and 4 gauge Wire and misc install supplies for battery change $100 (probably a low estimate, but I overkilled like a champ)
(Hint: it would help to have a stubby set of metric box end wrenches for the turbo installation bolts. Pretty tight quarters.)
Total Cost: $901
The real kick in the pants was the wiring/battery changes. Granted I think if you stuck with a 3" to 4" 90 degree reducer elbow off the turbo that you could avoid the need for changing batteries and the extra expense incurred there, then add the 90 degree long street sewer elbow as described in other threads. Now if you want to stick with a true 4" intake system with the K47 air box, then I see no other way of getting around this issue.
RaceDayMechanic: How did you adjust the wastegate on the HX40II?
True, I could have moved the battery... But honestly, I am not the best fabricator. LOL I do like the quality of your relocation though!
Plus when complete on mine I want it to look stock... Then it may leave a few people scratching their heads and saying "dang that thing hauls for a raggedy ol' 6.5"![]()
I don't care about my truck looking stock, Its mine and like everything else I own its Brucified
Bruce, where did you get the battery box for the relocated battery or is that a custom jobber?
Driving Impressions!!! (keep in mind I am still set at 20 PSI stock out of the box boost)
... Damn, this thing is much faster! Especially at speed, like a 60-70 roll on.
The biggest plus is there is no longer a "barrier" at 65 MPH that the GM-8 had when cruising. I always attributed this as getting over the torque sweet spot, this is not the case. The GM-8 must be hitting its comfortable flow limits at around 2250RPM... I know that sounds crazy, but the only explanation I have. The HX40II just keeps going up to 70! Well that's as fast as I got today anyway
Sustained boost is about 2-3 PSI lower at cruise than with the GM-8. I will have more data tomorrow at a steady 65MPH on the interstate.
Boost spools up very quickly just like with the GM-8. Really no big difference here that I can see... Granted I really had to keep my foot out of the throttle to stay below 15 PSI!!! Once the wastegate gets set properly at 14-15 PSI max this thing is going to be deadly
That said, the HX40II is FAST! Again I could barely get over 1/2 throttle due to fear of overboosting and the Burb still kicked ass!
... Life is not all roses though. The Pyro told the sad story... From what I can tell, the Pyro temps are about the same as with the GM-8. Again, limited seat time, but cruise still set about 600F, take off briskly around 900F, sustained take off to 70MPH about 1100F... In reality though, a hard run to 70 MPH with the GM-8 and Heath GL4 chip would get hotter than 1100F and you would have to back off a little at the end. Maybe I am being too hard, but the temps are a tad better, but nothing to write home about. More to come with more miles.
Overall I like it! The power alone is worth it! But the real bonus I think will be less boost at cruise as well as better breathing at cruise = better efficiency. I can cruise at 70 with ease now where I could not before.
Bruce what are the dimensions of the elbow that you used coming out of the airbox?
