Slim Shady
DEATH BEFORE DISHONOR
- Messages
- 1,523
- Reaction score
- 32
I left the brass ring in place... Someone post some pics on how to remove it and what the actual difference is.
... $ wise it depends. But yes I agree that they are within a couple hundred of each other.
Basic HX40II:
- Turbo $280
- Downpipe and fitting $115
- 2.25 to 2.5 coupler and t-bolts est $15
- Mouting bolts est $10
- Oil drain hose extension est $5
- 90 degree 4" to 3" elbow and t-bolts est $25
- reuse existing air intake $0
= $450*
* Since it seems that I am the only one sharing the COMPLETE parts list and $$$, someone feel free to input your real costs as well so there is more of a sampling. * (especially on the other site, there are loads of pictures but very little of $ or how-to. this is a much much better discussion thread here on TTS)
** My costs were whacked by the true 4" K47 intake and battery upgrade with The Big 3 0/1 wire install. **
The ATT seems to have a 3" inlet so that you can reuse the existing air intake system. I think the chopped up intake manifold is less than appealing on the ATT intstalls though. Also once in place with the HX40II, the 4" air intake is pretty cool(whether it adds anything productive HP wise is another question though, lol)
I still think for towing the ATT is the way to go. For day to day HX40II. YMMV, that was my logic anyway.
Pillow are those estimated costs or actual known costs. Also cutting the intake back was necessary since the ATT turbo sits one half inch forward and a half inch higher. I wonder if you would reconsider the chopped up intake after seeing the new silicone intake set up for the ATT.
I will get a picture
What is done going from the four inch on the hx knock off to the standard air box. Silicone hose is expensive last time I purchased them. If you are getting them (silicone five ply) that cheap (25) and hose clamps please let me know where. Thanks
Also didn't the price go up on the hx knock off from the original 280 dollars?
Has anyone gotten any solid numbers on the back pressure readings at various boost readings and intake temps on 90 degree days under sustained boost? I think Tim Turbine Doc covered most of that with the A team Turbo and Buddy did the back pressure calculations.
Be nice to see numbers side by side, Small 14 cm housing verses the larger A-team housing. Sorry for the questions but banned at the other site and can only ask questions over here.
