racedaymechanic
Active Member
How did the air box fix between the fender and the heater core return hose? Can you take a picture of it?
I didnt take any pics but I didnt have a problem, ill look at it tomarrow
One last question that I do not think has been addressed... The oil drain hose. Can the stock GM-X drain be reused or is a custom drain need to be made?
... All the parts will be here in the next couple of days!![]()
Question for you guys with more experience, would you choose this turbo upgrade over the Walking J?
I am leaning towards the Walking J turbo and tune for my Burb, just curious what you would choose?
All parts arrived...
One of the silicone 90 degree connectors is 45 degrees from siliconeintakes.com so they are sending out a new one today. Bad mistake, but good customer service to make it right.
The turbo of course is cheapish with some of the tapped areas needing cleaned with a grinder. Nothing serious, but still not something you are going to run straight out of the box. The turbine itself looks fine though and spins nicely.
Onto the install!!! Enough jawing online! LOL
I just ordered my turbo last nite along with all the plumbing for my air box and intake manifold from silicone intakes!
I agree that it is too early to tell... Also no one has done a back to back HX40II to ATT comparison that I am aware of. Most of this is relative to the GM-X turbos that have been replaced from stock.
IMO a turbo upgrade is only needed when increasing boost over stock and adding a performacne ECU for daily highway use OR towing heavy.
From what I have gained the HX40II is better suited for street driving/performance whereas the ATT is for towing as it has the best flow/backpressure out the exhaust side.
FYI I am a dealer for Silicone intakes and would love to sell you anything they offer for their price, I need the business
I wish i knew that! I just bought about $100 worth of stuff from them last night.
maybe you vendors ought to list everything you sell in your sigs
THIS!!! Go ahead wares whoring is ok here, we wont ban you
... I just gave them a little over $100 myself earlier this week. LOL
FWIW I will produce a complete parts list like Car Craft when complete.
Issue of the moment: the outlet pipe from the turbo to the intake manifold is 2.25" to 2.5", so a reducer silicone adapter is needed.
