MrMarty51
Marty we probably have a good shot of the heads being good on the old 506 engine. It never overheated.
Yup. The old engine is not going anywhere.Marty, if you do order a new engine, save on your old block! they are hard to find without cracks the 6.2 I have is cracked. the 93 is unknown but has a 99 engine. and my 95... well even if it's not cracked there, the starter mount point is cracked LOL
I am curious though on your block about bore measurements if the wear is worth having bored. wonder if it's within tolerance to just have it honed and re-ringed pistons even coated pistons from Chris with gapless rings. iirc he mentioned that coating the pistons would bring a slightly worn engine back to life with some gapless rings. how much blowby did it have if any?
if BigT's old heads are good you might have enough goods to build on your block and make a sound engine
I did not ream the ridge from the top of the cylinders. I was able to wiggle the pistons and press them on through the ridge.
The top spot where the Pistons stop, there is a visible place where the rings stop then start their downward travel.
Yeah, i am hoping that the heads from Your 506 will be in good condition and be able to be used.
I would very much like to go ahead and build this engine regardless that I most likely will never be around long enough to wear out this Optimizer thats on its way over.
