dbrannon79
I'm getting there!
Just curious,  how much
 was inside the water jackets after pulling the plug and freeze plugs out?
Got Me concerned.I'm surprised there was that much clearance behind it
Not much visible, have not rinsed it out yet.Just curious, how muchwas inside the water jackets after pulling the plug and freeze plugs out?
Probably be the best thing to do.I would be cautious about letting some of the local dealerships do much on older rigs. I know it will be more time and cost, but why not let Chris have a go at it. you know it will get done right the first time!
Ouch!!Pretty sure all of us should have our “heads worked over”…blunt force trauma worked over…for trying to keep these relics on the road. Not that it would dissuade us though
Top of my head is bald. Loaded with white and discolored scars. Looks like a road map of Germany or some other state/country with lots of roads.No 6.5 related parts were harmed….
That was probably Bill’s differential or the transmission jack that caught me not paying attention or pick something on BigT’s burb. Doesn’t quite rank up there with the cheek cut he got from the cross over though.
I don't think that's what Marty meant by having the head worked over.Pretty sure all of us should have our “heads worked over”…blunt force trauma worked over…for trying to keep these relics on the road. Not that it would dissuade us though
Leave a truck door open, come out from under it, go to stand up and bump the knoggin on the under side of the door.I don't think that's what Marty meant by having the head worked over.
And that is why we always had to wear hard hats safety glasses and hearing protection.
Do when we bumped out noggins, it just jammed our heads down betwixt our shoulder blades.
I wonder how many neck injuries that caused?
Baseball caps is the worst.I always hit my head way more wearing a hard hat.
Yes, heads can interchange left to right.From what I have read this is a common thing. There is a fix for it with inserts iirc. I personally would run them if there weren't any coolant issues, but lets see what others say. Maybe the heads off the engine BigT pulled are in better shape?
Question: are both heads the same, say two engines the left heads are fine and the right's have cracking. can a left head be used on the right side?
That crack on the No. 8 cylinder actually has a chunk or two missing from out of the crack. Like it will be about near shattering along the line.From what I have read this is a common thing. There is a fix for it with inserts iirc. I personally would run them if there weren't any coolant issues, but lets see what others say. Maybe the heads off the engine BigT pulled are in better shape?
