SnowDrift
Ultra Conservative. ULTRA!
I drove it.
That's all.
First time since about August 2022.
That's all.
Good to hear the rig is running well. How did those headlights work for you?890 mile straight shot from Centralia WA to home. Spousal unit came down with the crud. Trip over. Put it in the wind about 0430 Pacific. With multiple stops for, er, needs and some really good food in The Dallas, we were home B4 10pm Mountain. I don’t drive the truck over 70-75 unless I’m passing or showing off a little. So, the Google est. of 12:44 minutes was wishful thinking across ID and UT where the limit is 80 mph and I was just moseying along holding up traffic at around 73 av. Still, 19-21 mpg with righteous cross winds, lots of climbing and steady 75 through Salt Lake wasn’t bad.
Will do a rinse and repeat next month so I can spend some time with Bill.
Kinda mixed. This was actually the first extended drive with any real night time driving.Good to hear the rig is running well. How did those headlights work for you?
Mine surged better than that and made waaay more smoke…. before I fixed it.
These the housings I suggested?Kinda mixed. This was actually the first extended drive with any real night time driving.
Illumination and beam cast are all one could want.
Alignment…yeah, not so much. The headlight housings don’t stay put. Slightest pressure (cleaning bugs off for example) and they move and stay in the new position. Yesterday morning in the fog it was apparent I’d bumped the driver’s side so, pulled over, bumped ‘em back where they sorta should have been and continued on without illuminating tree tops on the right side of the road with the driver’s side light.
Not sure why you are losing adjustment. You’ve seemed to have fitment and adjustment problems with every housing you’ve tried.Yes. They are the DWVO'sView attachment 87481
Maybe its because the manufacturers only produce POS anymore?Not sure why you are losing adjustment. You’ve seemed to have fitment and adjustment problems with every housing you’ve tried.
If you get the chance- do a detailed video, take one minute per side or more of them mounted to the support. Maybe someone an spot something.Maybe its because the manufacturers only produce POS anymore?
Will do on the headlight vid. They are mounted to the core support with all four bolts so it’s simply quality of workmanship with the adjuster assy.
Today I’m just doing a couple small things like a post trip oil change and exchanging the air cleaner set up back to the Heath 1st Gen that S&B partnered with him on (and then screwed him over).
The second version seemed a little loud and since the Frau now has to enjoy the ride and turbo whistle isn’t a fan favorite….
Then it’s repair / replace the seat back release handles. Both sides broke on this trip…old parts…guess it was their time. RIP
