Paveltolz
Доверяй, но проверяй
Did a similar alignment on my truck after swapping in new ball joints, bushings, tie rods, centerlink etc. I used 4' levels centered on both wheels. Centered the steering wheel and then adjusted the tie-rods to get the back and front of the levels an equal distance from each other. Checked distance from the frame on both sides and re adjusted tie-rods again until they were parallel to the frame. Double checked for equal distance between the levels again...rinse and repeat. Didn't know about the toe-in but, I was just getting things ball parked to take it in for an alignment since I needed camber done too. They said I was pretty much balls on. Truck drove better before they did their stuff. Probably should have just redone what I did after they got the camber right...something else to do to pass some time.Well, today I pulled my 95 in the driveway again to re-do my hillbilly driveway alignment job. this time I got the truck as level and straight as possible, then used two small jacks on the LCA's up close to the ball joints to get the tires up off the ground. re-checked the level of the truck going off the radiator support. then with my magnetic torpedo level that has a level bubble with increments on the brake rotor hubs, adjusted the camber to as close to zero as possible. also checked the caster by placing another level behind the spindle lining up with the center of the lower ball joint and the upper. verified both sides were at a positive caster and at the same increment mark.
lastly I took two straight edge levels resting on the lower section of the rotors and a tape measure front and back of the rotors to set the toe. got it to 1/16" toed in. (at work we set the big trucks to 1/16 to 1/8" in) took the truck out for a drive and this made a huge difference. tracks straight and no pulling to ether side other than when your on a road with a steeper crown. I drove on a couple roads in town that I knew had a steep crown in both directions. I had to correct the wheel the same amount both ways left and right. so I will call that good enough.
I'm still getting some clunks and clanks turning sharp. I think this is from the coil springs since when I did the LCA bushings the rubber on the top of the springs were mostly gone. need to take to a shop to verify this. as for the gear box.... well I'm sure it's shot. I still feel the truck shift a little side to side as if the front tires will turn slightly when I hit a bump or rut in the road, but it's not near as bad as it was before I did this today. when the tires are up off the ground you can lock the steering wheel and still turn the tires side to side a little. I need to see what the best and affordable option is for a good gear box. RA wants around $400 for a new one, they show two brand but I'm not sure if these are good ones or not. for the red head ones, I have heard some folks have issues and others don't but theirs are all reman units. I would like to get new if possible.
More Information for BBB INDUSTRIES N5030128
www.rockauto.com
More Information for EDELMANN 3000
www.rockauto.com
