Big T
I too would like to know how to replace the hinges and still get proper alignment. sure would have been nice if they left them bolt on instead of welded in place.
I suppose it would be a lot of work, but one could pull the door off, then drill through the hinge and pillar, cut off the old hinge and use the holes as a template to drill the new ones . make a backing plate to go inside the pillar for support with the same holes drilled. then bolt it all together and be done without welding them back. even once everything gets drilled, the holes in the pillar could be egged a little for minor adjustments like the old trucks had, also tack weld the nuts to the inner plate.
The existing hinges appear to be welded on. How would you remove them? Grind them off?
How would you get access to inside the pillar?
