dbrannon79
I'm getting there!
Well the kit showed up yesterday afternoon and it was the right on this time
I compared the sector shaft bearing on the shaft, the old one probably had at least 20 thousands wobble play where the new one has very little play. Got the gearbox all put back together. took me a few tries getting all the little ball bearings in the worm gear with the input shaft centered!! took the input shaft nut to work to see if one of the welders can scab together a spanner wrench so I can torque the nut.
something I did notice was the sector shaft bearings, the old one has a plastic cage holding the rollers and each roller is spaced out. the new bearing has all the rollers side by side, no spacing between each one similar to how a u-joint cap has the needle bearings. a much better design. the kit I get is a Plews Edelmann 8781 kit, same brand of box I will be ordering if this rebuild doesn't work out. only thing that was not included was the sector shaft cover gasket. I can re-use that one.
