Rhinopkc
Bull in a China Shop
Only thing I don't like about the Kennedy last time I looked into that as an option it wasn't self priming.
I'm installing a Racor with the priming pump, so that should cover the priming concerns.
if you ever use that priming feature, you'll wish you would have bought a self priming pump, yes it primes, but ain't fast
We'll I'll trump your disagree with my disagreeI completely disagree.
Whats wrong with the 93 HO and/or Heath HO.....They both do a good job, if your not drag racing?
Racor prime will prime it, just takes time so you don't need to use mity vac.How about my Mighty Vac knockoff at the filter mgr?
We'll I'll trump your disagree with my disagree,
I didn't say the racor prime doesn't work, and I do use it even to point of pushing fuel thru to the vent on the filter manager when I do fresh change of filter on the racor, reason I bring it up for the Kennedy pump as a caution if for some reason you lose a suction on the pump (like a sloshing of fuel, or partially snotty filter strainer), you are forced into a reprime situation where a positive pumping pump will keep itself primed better than a kennedy type pump may, my caution is not that I'm recommending that one not prime using the bulb provided.
As for noisy walbro, I don't know the why there, maybe I never will, or maybe our definition of noise isn't the same either, since I'm deaf in one ear, and hard to hear out the other after years of being around jets.
My walbro was used but good when I bought it, maybe also damaged and why it makes more noise than yours
but then again my PMD is still on the pump also after 6-7 years..........
Too late. Can always call a tow truck...: :rofl:
