It's a good feeling to wrap up a 'fix'.
Tell that brother he owes you a crossover.![]()
copper pipe/tubing should flex easily enough
Once you crimp your pipe with a basic ex clamp, your xover kinda is not a two piece anymore me thinks..
I found some flange bolts with a 15mm hex to work with my warpspeed.. It was tight.. Impossible with traditional generic 10mm bolts, they have a 17mm hex.. too close to the pipe.
Turbo should be a welcome change..
