Unless she already has a ring, the engine will probably outlast the GF. If you want red, make it red. Just don't go pink. LOL.
As you can tell im not good with paint...
I cant wait to install it, im sure it will give me a tad more turbo lag, but it will be nice for the heavy hauls. Im going to remove all my A/C, so the only thing that will be in the way is all the hydraulic hoses and fittings..
Not sure about your truck, but my rad is too wide for the IC to fit with the rear facing outlets. That's why I need to cut them off and reposition them, or at least one of them.
Lag will be marginal, pre ATT with the high IATs of the GM turbo IC for me was the best choice as unlimited supply of cooling medium, now with better overall turbo output WMI will be sufficient, the IC is going into my ATT'd burb since I have it no need to buy a second WMI kit.
As far as finding someone to do your tube fab work, I was in same situation as you, I can do basic welding repairs, but I would not stake my engines life on my quality, see if you have a shop nearby that does Ricer IC installs that is what I did rate wasn't that bad to have them fab it, plus they had all the tubing/connectors handy so a 1 stop trip.
