The engine is pretty much assembled. Still have a few things, like the intake and turbo to bolt on. Hope to install next week. No real problems with the assembly, but I did discover a few more things. First, the motor mounts take metric bolts, the original 6.5 bolts are grade 8 SAE. I also discovered the water pump backing plate is different for the GEP NA water pump vs the reverse rotation pumps. I had the GEP one all ready to go, but had to use the original backplate from the Sub at the last minute. Other than that, no real surprises.
Installing the damper with my home made damper installer
Lifters and retainer bolted in
New freeze plugs and block heater.
Getting the timing tag set to TDC.
ARP head studs in. I used GM thread sealer, so hopefully no leaks!
Fel-Pro head gaskets
Heads torqued down, rocker arms in
Here it is assembled. Intake is just laying on the heads, not bolted on yet. Glow plugs, injectors & lines installed, exhaust manifolds are bolted down.
I'm changing the CDR a bit. Instead of using the valve cover, I'm going with a oil fill vent.
Yes, I made a trip to the powder coaters! Oil fill is a combination of two fillers. The vented fill had the lower height fill with the older type cap. I had the tall filler with the newer type cap. So I cut them in half and had a friend tig weld the relevant pieces together. I now have a tall vented oil filler!
I have changed around the fuel pressure sensor on my fuel manager, I'll try and get a picture before its bolted in. Stainless oil line is for remote mounted OPS sensors.
GM-8 Turbo is not bolted down yet.
Detroit Diesel Power!
