Well I do it with dial indicators to be as exact as possible but getting close may be good enough.
How would I know if the IP gear is off?Degreeing a cam, or checking the cam or gear install isn't a beginner thing that is easy to do and get right. I always check myself, start from scratch more than I like, but it pays to be sure while it's on a engine stand.
In your case check the IP gear first, maybe you get lucky.
It's over my head.Degreeing a cam, or checking the cam or gear install isn't a beginner thing that is easy to do and get right. I always check myself, start from scratch more than I like, but it pays to be sure while it's on a engine stand.
Correct. This is extreme hot rod mode where you know it will fail- not if but when.One should always be careful of running an engine with pump timing off by a tooth,etc.I’ve personally seen cylinder heads with melted or deformed precups because of this.I wouldn’t run that engine again until the dots/marks are verified to be right.
I wonder if the engine sounded like it had a miss ?with those two lines crossed.I also came across one 6.5 several years ago with injector lines 2 and 4 crossed over on the injector end.Some guy had the two lines in the wrong place.The injector tips on those two cylinders were practically melted away.It was unbelievable.
I would definitely check the keyways against the markes on the gears before proceeding, if that works.I just made the purchase of the timing gear set, not planning on installing it any time soon, now I’m almost fearful to do so.
To be honest it sounded okay and the engine was pretty steady when looking at it under the hood but when I stood back a second and observed those lines it definitely didn’t look right.It also had two misfire codes for 2 and 4 and the minute I reversed the lines it performed even better but damage to the two injector tips was already done.Pretty much deformed on the ends.I wonder if the engine sounded like it had a miss ?with those two lines crossed.
Haven't have time. Hopefully we will be able to get to it this weekend.
