got it. I just ordered a set from rockauto.No, the timing gears are where the trouble is, moving the IP gears and not the gear set won't fix anything.
I hadn't thought about it that way but that makes perfect sense. installing and setting up a regular timing chain set so it's on the money, then without moving anything slide it off and putting the gear set back on...If you install a stock timing chain/gear set. Then without turning the crank or cam- slide them off and slide on the gear drive- you will be correct.
Degreeing the cam is ideal.
good Idea. I will cancel my order.If you install a stock timing chain/gear set. Then without turning the crank or cam- slide them off and slide on the gear drive- you will be correct.
Making the dots is as simple as marker when on the engine, slide off and set on bench. Center punch then start to use a 3/16 or so drill bit. Just enough to make the dot.
Something I am contemplating is putting my cam gear on a lathe and removing a lot of the gear face so it is the same basic profile as the stock gear.
The weight is not a good thing for performance. Really shouldn’t hurt anything but won’t hurt to lighten it either.
will do. Thanks!I hadn't thought about it that way but that makes perfect sense. installing and setting up a regular timing chain set so it's on the money, then without moving anything slide it off and putting the gear set back on...
@Rodd if you do try this. post a pic of the chain set installed and lined up, then another with the gear set slid back on without moving the crank or cam. you can take a paint marker and dot the crank and cam where the dots are on the chain set so we can reference the diference on how the gear set is mis-dotted. then make you some dots on the gear set so later down the road you have the correct marks on it in the event you ever have to pull it apart again.
