dbrannon79
I'm getting there!
I think the No.1 is the same stuff as the old Indian head shelack brown bottle with a brush. some tuff stuff and never hardens.
Not sure where to go from as far as figuring out the head gasket issue.
You are correct. I assumed my son did that. I just asked him and he didn't. He's doing that next.Again as I wrote in post #268: look for bubbles to see what side or both be the problem with T stat crossover removed. Remove valve covers and see if you find the coolant leak plain as day around a stud. We are assuming it's head bolts or gaskets vs. cracked block, cylinder, head.
Coolant in oil can also come from the timing chain gear cover housing or internal water pump bolts.
gm8, not sure of boost. It has a turbo master. It was 8-10 psi before rebuild with same length on the screw. Not sure of fuel.What turbo, what boost, what exhaust pipe, how much fuel?
