Did you gap the rings or just install them as is ?
Just installed them. The machine shop gapped them when they resleeved the block and balanced everything. When my son pulled the pistons on Friday he checked the gapping of the rings and they were all within spec.Did you gap the rings or just install them as is ?
No. I didn't receive any powder with them. That wouldn't cause the discrepancy with the compression on each bank would it?You are supposed to break in gapless rings with their powder. Most engines people just use oil or some oil concoction mix. Did they use the powder?
He followed the instructions ARP sent with the studs.
With the HG's both torqued properly it appears to be over pressurizing the coolant system and it spits out the expansion tank like there's a blown HG. What do you guys think?
One other issue is the head gasket leaked on the passenger side.
We decided to forego the gapless rings for stock rings.
The guy said that they do lots of gapless rings and every once in a while they have compression issues.
The water leaking is internal. Nothing leaking on the outside.
I like to use the permatex No.1 that comes in a squeeze tube for headbolts, any bolts, that goes to water/coolant jackets.Yes the water issue has been figured out. It never got into the oil that we can tell. The oil is not milky. Hopefully the black permatex will do the trick.
