crash2win64
Same to you brah ^^^^^
What didn't happen ?videos or it didnt happen.
all of these outlandish claims of power and boost numbers. A little video proof isn't much to ask for.
WTF??? on another thread you said boost equals more airflow. Now you say limit the boost????????:???: I don't believe you know much about any engine once they get past stock hp. Or are you just confused?
Do the math. He got his pump cc'd, has marine injectors, and a 66/68/16 turbo, and can pull 4500rpm easily.
Or you could come in here an go for a ride.The math doesn't add up, and now that I've seen claims of 140cc's, 110+cc's over 3k, I'm more skeptical. I'd just like a little paper and or video evidence. That's not unreasonable.
I laughed....The turbo 6.2turbo runs is efficient up to around 50 psi. The only time boost hurts power is if you have excessive back pressure!!! I'm just gonna go back to working on some engines here instead of posting conflicting and misleading info! I can learn more by doing than i can by reading!
Experience.... :thumbsup:
You'll never learn, have you ever tried to compress air to 4000psi? Do you think your engine likes it any better? Engine A compresses to 3000psi, Engine B compresses to 4000psi, which is happier and will use more energy? Now what did compressing the air 1000 more psi gain me? Thats the million dollar question. NOTHING!!!! But it cost you the energy and heat to do it. And why did it gain me nothing? Because I already had enough air for the fuel I injected. If you have more fuel, you might be able to use the extra air mass, but this is how you tune something, not just throw as much boost at it as you can. And even if you thought only backpressure was an issue, I dont care how efficient the turbo is youll have more backpressure at 40psi than at 30psi, so that is additional parasitic loss. And the backpressure values should be taken at a steady state boost, like under load, climbing a hill and pushing 20psi of boost constant, what is the steady state backpressure. There are about 10 different concepts here and you boil it down to more boost is more air and thats good.
Because you cant read and comprehend you have no idea what is conflicting, its just over your head. Which is fine, just stop posting about how confusing it is.
Chill ....
I think his pump maxed out at 160cc but I'm not exactly sure. We have a 29 plunger pump that spools an hx-55 that easily pegs a 30 psi gauge an it runs right with his truck.
And I bet he's bent more connecting rods than you too. Go back several pages and look up some of the stuff he's done. I really don't think he's pullin one over on you. Just sayin.
If anything you just proved buddies claim. A .29 plunger DB2, running 30psi... runs right with a 160cc DB4 pushing 50-60psi. You realize what you just said right?
Stop posting empty claims. Post some kind of proof. ET and weight slips, dynojet, video of said boost gauge spooling from 0 to max, a flow bench data spec on a pump.....
Yeah, 6.2turbo is just randomly logging in, posting fictitious numbers, about a fictitious vehicle, that only exists in his sleep.
somehow, this fictitious vehicle randomly bends rods, and pukes it's guts on the road.
and... somehow, I rode in this fictitious vehicle. Musta been sleeping...
