buddy
Active Member
Got this thing running again. This time a stock compression 6.2. Turned the fuel back a lot. Having trouble getting any power past 3500 rpm. Boost peaks at 25,and drive psi is never more than 25 psi. At low boost, drive psi is lower than boost psi. More timing helps only slightly . Midrange power is fine. Low end power is totally gone. At least it starts easily. I said it before, I think it matters if it's too lean.
I think 18:1 for air:fuel ratio is about the best for power at high load. So not very lean at all.
Could you swap the gauge inputs to see if the gauges are effecting the boost/drive pressure readings? Is this with the 16cm^2 HX50 turbo housing?
Glad you got it running.
