You still having good power ? As we understand it, the internal housing pressure adjusts the timing to compensate for the increasing rpm's of the motor.....we had a problem with one of our pumps, pulling air in the seal for the advance plunger.....could watch the bubbles when moving the lever externally. When you are adjusting your timing, are you using your timing meter ? Where are you set at at idle, as compared to a higher rpm ?
Could you post up a video, so we can see how the Tahoe is running now ?
This timing issue, among others is the reason, that if we are able to just enlarge plunger size and the corresponding charge and delivery passages, we prefer to attempt that route, and try to keep the pump as stock in it's operation as possible. Keep at it, when you finally have the formula figured out, many will be trying your mods to the pump and injectors.
