dbrannon79
I'm getting there!
Found the ground problem. Was on the frame at the fuel tank. Got the lines primed and now I’m at a no start condition and dead batteries. Oh it just gets better!
I will be looking into an inexpensive gauge to mount in the cab real soon because of this experience
I would have never thought of that! Curious though. Did you use something to keep the fuel from going into the cab incase of disaster? I was looking into that and only found what they call an isolator but those puppies are as expensive as a high dollar electric gauge set!I use a boost gauge from Advance Auto for my fuel pressure gauge. I like the boost guage for fuel pressure because it'll let you know if you ever go into a vacuum.
Whoa there big guy. Something’s a miss here. Either I didn’t understand you right, you didn’t understand a thread right, or whoever wrote it didn’t understand right.A thought just occurred to me when reading another thread that the return line fitting on the IP has a pressure regulator and check valve built in. I’m curious if these things are common to fail. Just searching online there are several threads out there on them
Yes, with the remote mount filter I have and eliminated the original filter manager, it uses 3/8" line from the steel line from the lift pump to the IP, but I have not enlarged the fitting that's in the IP. that was the last step, I just need to buy a fitting for that.Are you familiar with FTB MOD? Enlarged fuel line from filter to ip using 3/8 line including ip fitting instead of factory 5/16”.
